I just purchaed a used 2018 Equinox Premier with 2.0 AWD with 22K miles on it. The motor seems to run smooth and tranny seems good also. I did notice that when traveling at about 60mph and it shifts into 9th gear, there seems to be a vibration that comes from the drive terrain that causes a bad drone noise in the cab. The door panels will vibrate and it is just anoyoing. It will do it when the motor is getting lugged at about 1500 rpm. If you give it more/less gas with out it kicking out of 9th gear, you can vary the vibration and noise in the cab. Is anyone else experencing this issue?
