Audio & Electronics
OBS speakers
This is a discussion on OBS speakers within the Audio & Electronics forums, part of the Equinox, Terrain & SRX Modifications category!
Do some of you know if the stock speaker are 2 or 4 ohms? I will maybe upgrade the speakers ...
Old 03-06-2013, 12:54 PM   #1 (permalink)
Default OBS speakers
Do some of you know if the stock speaker are 2 or 4 ohms? I will maybe upgrade the speakers on my truck without changing the HU (see other thread called radio upgrade).
I'm a little bit concerned about what kind of ohms are on the speakers, I don't want to throw 200$ on the speakers and get something worst because my OEM radio can't play them.
If someone ever change speakers with keeping the OEM HU or know the ohms, it will be much appreciated.
thanks
Pascal
Old 03-11-2013, 06:11 PM   #2 (permalink)
Paul79UF's Avatar
Paul79UF is on a distinguished road
I'd recommend chatting online or calling Crutchfield.
I was surprised by how much they knew when I needed help years ago installing a system.
My Equinox DIY Guides
Paul79UF is offline   Reply With Quote
Old 03-11-2013, 09:13 PM   #3 (permalink)
thanks buddy! didn't think of them but I like the idea!
Old 03-12-2013, 09:26 AM   #4 (permalink)
Default Re: OBS speakers
That helped me out a time or two before!
Sent from my DROID RAZR HD using Tapatalk 2
Old 03-27-2013, 08:39 AM   #5 (permalink)
Ralphwhite is on a distinguished road
thanks
Pascal
installing speakers have always been bit tricky. Have you installed them without changing HU?
Ralphwhite is offline   Reply With Quote
Old 04-01-2013, 04:08 AM   #6 (permalink)
VictoriaTownsend's Avatar
VictoriaTownsend is on a distinguished road
OHMS doesn’t have much effect on the audio quality and when it comes to speakers you should consider about watts.
VictoriaTownsend is offline   Reply With Quote
Old 10-08-2013, 06:47 PM   #7 (permalink)
Robarino is on a distinguished road
Certain headunits and amps expect the speakers plugged into them to be within a specific OHM range. OHM is resistance. If the resistance is too high or too low it may affect the output of the amplifiers.
Watts = Resistance x Amps Squared.
OHMs matter.
Robarino is offline   Reply With Quote
Old 10-09-2013, 11:54 AM   #8 (permalink)
OHMs matter.
Yes this is true! Your amplifier may be able to power the sub by how many watts is puts out but if you have a stable 4 omh amplifier with 2 omh speakers, the amp will end up quitting on you.
