-   -   OBS speakers (http://www.chevyequinoxforum.com/f11/obs-speakers-885/)
prheaume 03-06-2013 12:54 PM
OBS speakers
Do some of you know if the stock speaker are 2 or 4 ohms? I will maybe upgrade the speakers on my truck without changing the HU (see other thread called radio upgrade).
I'm a little bit concerned about what kind of ohms are on the speakers, I don't want to throw 200$ on the speakers and get something worst because my OEM radio can't play them.
If someone ever change speakers with keeping the OEM HU or know the ohms, it will be much appreciated.
thanks
Pascal
Paul79UF 03-11-2013 06:11 PM
I'd recommend chatting online or calling Crutchfield.
I was surprised by how much they knew when I needed help years ago installing a system.
prheaume 03-11-2013 09:13 PM
thanks buddy! didn't think of them but I like the idea!
dietz4ibanez 03-12-2013 09:26 AM
Re: OBS speakers
That helped me out a time or two before!
Sent from my DROID RAZR HD using Tapatalk 2
Ralphwhite 03-27-2013 08:39 AM
thanks
Pascal
installing speakers have always been bit tricky. Have you installed them without changing HU?
VictoriaTownsend 04-01-2013 04:08 AM
OHMS doesn’t have much effect on the audio quality and when it comes to speakers you should consider about watts.
Robarino 10-08-2013 06:47 PM
Quote:
Certain headunits and amps expect the speakers plugged into them to be within a specific OHM range. OHM is resistance. If the resistance is too high or too low it may affect the output of the amplifiers.
Watts = Resistance x Amps Squared.
OHMs matter.
dietz4ibanez 10-09-2013 11:54 AM
OHMs matter.
Yes this is true! Your amplifier may be able to power the sub by how many watts is puts out but if you have a stable 4 omh amplifier with 2 omh speakers, the amp will end up quitting on you.
